Scuttle drain holes
Water in footwell of Fabia W reg, can anyone point out where scuttle drains are please.
If it's the same as my Y-Reg TDI then either end of the scuttle between the inner and outer wings. You'll need to remove the wipers and the plenum cover the clean the scuttle out though.
Other versions also have two drain holes in the rear engine bulkhead - one below the ECU and another corresponding one on the other side near the brake servo - both can be accessed from the engine compartment.
Thanks Skomaz, when it stops raining I'll check those out. Happy New Year
