replacing front bridge bushes
I want to replace myself these bushes,are easy to fit?Can anyone advise me?
Thanks!
Don't think I've ever changed the subframe mountings before.
Fairly easy job to do, as you can lower the subframe down on a jack without removing it completely.
OEM vRS bushes are one bush per side, but if you use the uprated bushes from a Seat Leon Cupra R they are in two halves each side which make refitting them a piece of p!$$.
When I changed mine last summer I fitted the uprated ones as I had some lying around, however the original ones I took out were still in excellent condition and to be honest didn't really need replacing (9 years old!).
You will also need a full wheel alignment afterwards too.
Steve
P.S Nice picture :rofl: (my car appears all over the place!)
First,is not my picture,I found it on the forum.
So,I need to jack the subframe individualy ,that was my first concern.They certainly need replacing,are very cracked(2001 MY).I'm glad to hear that I don't need to remove completely the subframe.
