Access To The Cd Changer?
i will jump around in the boot whilst you drive rob.. see if it skips then...
Certainly would be more comical than speed bumps! :D
Rob.
Before I corrected the 'orientation' dial on mine, driving over manhole covers was enough to make it skip :D
I tried pulling, pushing and frigging, but it remained firmly locked into position :(
So how do you remove it?
Q. [/b]
How do you frig a cd player? :confused:
By fiddling :D
rob's been seen staring into man holes on a friday night....
So immature...
:p
Rob.
:rofl:
come on rob you know you smirked!
Well, looked at the player yesterday, and was rather confused as it was set to horizontal.
Then I noticed there is actually a control on each side, and that one was set on horizontal
and one on vertical...probably not good for the unit! :o
Rob.
I noticed these things as well... Odd degree angles though, but they were set to the same on both sides, so I guess it was correct.
On the standard one? Actually, I didn't look to se what they were on that... :D
Rob.
