Access To The Cd Changer?
I'm stumped... How did those Skoda engineers get the CD changer in the boot? I tried to find any screws, but none that I could feel. I tried pulling, pushing and frigging, but it remained firmly locked into position :(
So how do you remove it?
Q.
4 bolts 2 each side or if you want to remove bracket as well remove the 2 nuts that hold the side of ya bumper on.
What, no mention of the hammer ???????? :eek:
What bolts? There is nothing but carpet around the changer? Or do I have to unscrew these on the other side of the changer, i.e. on the outside of the car?
The plot thickens... :)
If you pull the carpet bit firmly but gently with a wiggle it will come off, and the changer unit is screwed
inoi this by four bolts. :)
Rob.
or you could just rive at it like rob and i did!:D
So is that in a lifting movement (slide upwards) or pulling movement?
a little of both...:D
It's comes off horizontally, but needs a bit of vertical persuasion. Basically, pull it in each direction
until you feel it give a bit, and repeat until you have it out of the car... :D
Rob.
I shall give it a bit more force then tonight... Bit worrying though I might break things :)
Funny, I remember getting it out....... ;)
Rob.
Why do you have to wiggle when pulling the carpet? And what's best to do the wiggling with? ride.gif
The first time maybe! :p
Rob.
The carpet enclosure is screwed onto the change unit, with
gaps down either side. Into these gaps slide the "prong" type
things in the side of the boot.
And wiggling with your hands is sufficient, though a JML
Wigglomatic would of course make life easier...
Rob.
I never realised the changer was so well attached!
Mine has 2 strips of velcro to hold it to the carpet under the passenger seat and that's it :)
Better wiggle emoticon: shakin.gif
My new one doesn't even have Velcro to hold it! Not that it needs it, very snug fit... :D
And don't you wiggle your monkey at me! :p
Rob.
What's wrong with monkey?
Nothing, just keep it for the ladies... :p
Actually...has your CD changer got a "mounting direction switch" on it? Some way of telling the
unit at which angle it will be mounted, from horizontal through to vertical?
Mine has, and I set it to vertical when I was planning on mounting it on the boot side, but didn't
put it back to horizontal before putting it horizontally...still works fine though.
Anyone any idea what these switches actually do?
Rob.
Mine does has some sort of "orientation" control on it - a rotary (mechanical) dial on either side.
When it was first installed these were set incorrectly, and the changer skipped all the bl00dy time! Once the setting was corrected, it was fine :D
Hmm...I'll have to try it with proper CDs, see if it skips... :D
Rob.
proper CDs
:confused:
You got some special supply then , Rob??
Audio as opposed to MP3, should I say, as I'd imagine the MP3 buffering is longer...
Rob.
I guess if the changer has a skip buffer you might not notice it, even if it was skipping as a result of being in the 'incorrect orientation'. So if you're not having problems with the MP3s then I don't think it will show with std audio either.
Just a wild guess........:p
H
Depends really how the buffer works - if it's fixed memory usage but stores the MP3 in original
form, it will effectively increase the buffer tenfoldish. Guess I could do with finding some vigorous
speed bumps.. .;)
Rob.
