Blitz Dual-SBS Spec R Digital Boost Controller
I have remove this from my Octy vRS it is in full working order and all pipes and wiring loom plus full english instructions are present
These are top quality units and retail up to £400 as is used I am open to offers but looking for around £160 posted or can be picked up local in the Sheffield area.Some info below and a web link also
DUAL SBC Spec R
The Spec R features a dual solenoid that diverts pressure away from the turbo actuator to achieve higher boost. This dual solenoid is linked to a smart control unit installed inside the car, which allows you to control the boost pressure.
The control unit also displays live boost pressure.
The Spec R unit has four user programmable boost settings.
Scramble and gain settings are programmeable.
There is a boost warning mode, which can be pre set to visually and audibly alert the driver to an overboost situation.
The unit can also be programmed to reduce the solenoid duty cycle in an overboost situation.
It is suitable for both internal and external wastegate applications.
The Spec R can control up to 2.5 bar of boost, and is supplied with wiring and English instructions.
http://www.dcperform...s/bz-15059.html
what you running inplace of this ??
Hi There
This set up was removed at Shark Performance on Bens advice she just has a custom remap which works fine for me
Steve
That's strange so you back on standard n75???
This will limit your control wouldn't it ???
I got the same contoller car will be running lot more power!!!
