Front and rear alignment preFL
Hello
I know that tere are numerous discussions about 4 wheel alignment and which settings to use but I have run into a couple of conflicting values.
Can anyone confirm front and rear values that I can take to the garage doing the hunter hawkeye alignment or me. I just want to ensure I don't get front inner wear or rear saw toothing as I've just invested in 4 new tyres.
Forgot to mention. 2006 vrs on 18's.
Will
Edited by thewill
allias did mine Front
caster left 8
right 7.7
Camber left -1.2
right -1.1
Toe left 0.06
right 0.06
total 0.12
Rear camber left -1.3 right -1.3
Toe right 0.06 left 0.06 total 0.12 this was for my car, they are not all the same to allow for the camber of the road, pm allias for advice , his main bread and butter at his garage is four wheel alighnment . My car is a 56 plate petrol vrs lowered 30 mm
caster left 8
right 7.7
Camber left -1.2
right -1.1
Toe left 0.06
right 0.06
total 0.12
Thanks.
Wonder if it being lowered makes a difference?
I just want an end to the sawtooth droning!
What is your setup? Have you done anything to your suspension? Where are you based?
Hi,
To be honest it's completely standard.
Nothing out the ordinary, just had front bushes replaced by dealer.
I'm based around Chester and north Wales.
I will search for spec later but if you will have it done on Hunter then they will have correct and the newest data.
In this link on bottom of first post there is pdf file with spec for Octavia. Dont worry about year difference - it will be the same.
http://briskoda.net/forums/topic/217475-4-wheel-alignment-in-leeds-bradford-area/
Edited by allias
