glovebox light
I recently replaced the centre console trim and after pulling out the cigarette tray and the lighting fitments and refitting both the little light there and the glove-box light don't work, my question is what should be my steps to get them working again all other interior lights work, i checked the glove-box bulb and im pretty sure its an led replacement, it worked before i did the trim anyway, i have a bit of ocd about bulbs so id like to get them all working again :) oh also just so i can get a new bulb just in case what bulb is it?
Did you take the bulb out? If you did and it's an led then it's been put in the wrong way
no i didnt take the bulb out i couldnt figure out how to get it out, it worked before i took the cigarette comaptment light out and refitted it to my carbon ones then neither the little light in the cigarette ashtrayor the glovebox light worked
That lil bit of info points to a loose connection around where you've been playing. Look again at the ashtry light/wiring
When you take the ashtray housing out of the dash there are wires behind it so you have to be careful when refitting it you don't catch the wires and stretch them. The ashtray light clips onto the bottom of the ashtray housing so it may still be working but just fallen out of the clip
i will check is it connected to the glovebox light?
IIRC the glovebox light has a multiplug connected to it which runs behind the back of the ashtray. Might be worth taking the glovebox out to check if you've pulled the multiplug out
hehe this should be a fun day
You'll get to know your car a lot better LOL
lol by swearing at it haha, btw whats the trick to getting the glovebox light out the holder? the bulb i mean
Crow bar usually works lol
lol i gan get the fitting out with a screwdriver the bulb however is a rite pain!
found out the problem i need the housing for the glovebox light and the fitment for the ashtray light
Sounds like someone has been heavy handed lol.
Where abouts are you m8? There's 2 octys in my local scrappers.
haha birmingham mate a bit far away from york unless you can be my eyes and ears haha, and heavy handed yh for the ashtray light i think i went a bit mad with the screwdriver at the time as the car had bitten me once already and the glovebox light the internals where caput
