DRL install
Recommended Posts
Hi all,
Have installed a set of DRLs (http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_541305_langId_-1_categoryId_165688). Yeah, I know Halfrauds and all that, but these were the only ones I could find that fitted without messing around too much. (They're installed on the removable sections by the front fogs. To say they fit, well, *if* I was feeling brave, if would have been an interference fit! Two screws and one hole drilled, and that was to access the adjuster screw.
Anyway, I've got an ignition-swtiched source to turn them on. What I'm after now is the positive feed to the side-lights, preferably from the connector behind the light-cluster. (This will swtich the DRLs off via a relay, thus staying nice and legal.)
Can anyone let me know which pin is the + feed please?
Alex
Link to comment
Share on other sites
Hi all,
Alex
pick up yellow cable behind the light cluster.
Link to comment
On left side + pin is 10 and on right side is 2.I suggest that you take off the cover on light and check which wire goes to bulb and then check on the connector.
Edited by bfranc
Link to comment
Thanks guys. When it's made it's mind up about snowing I'll get out and finish that off. Will let y'all know.
Brfanc: am trying to keep it on the car side, just in case the cluster has to come out and no-one's noticed the extra cables ;) ;)
Link to comment
Pin 2, right-hand cluster. Spot on! Thanks! :)
Wired into the back of the main cluster connector, so headlight is still easily removed if needed.
DRLS now come on with ignition and off when sidelights come on. :)
Link to comment
B):thumbup:
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
