Better Octy vRS standard-brake-disc/pad replacements. Which?
Hi folks,
When I get back to the UK (just have to drop that I'm in not-so-sunny Barcelona ;) ), I have to change my front Octavia vRS discs and pads. I'm thinking of upgrading (slightly) while I've got the chance, so what do people recommend?
I'd like to keep the cost as close to standard as possible (ofcourse I'll pay a little more), be I really like better everyday braking. I've seen some Pagid Black Diamond drilled disks for around
Hi folks,
Hi folks,
Had these on mine for a 1000miles didn't notice any difference to the standard ones only the little cracks that appeared from the drilled holes.Got a refund in the end,if you do decide to buy them go for the grooved only.
Chris,
did you change the pads as well?
I got EBC grooved discs and Ferrodo DS2500 pads....and as you well known... my RS stop quite well.;)
I think I paid around
personally i won't bother...the standard brakes i feel give plenty of stopping power
Joel
Joel
..but also fade badly.
My set-up isn't as far as you could go but I can definately say it has a better feel and stops much better.
Once I have the fluid sorted it will be better still.
If you have a remapped car I say it's definately worth it.....as a minimum I would suggest the DS2500 pads and fluid.
Yup brake fade has scared me lotsa times. I will change them eventually :D
Surely the fade can be cured with a decent DOT brake fluid?
And maybe SS hoses.
Bit less extreme than pads/discs?
Yes adrian this was going to be my next step as i think mine fade badly also trying to keep up with silver octys didn,t help ever:D .
And maybe SS hoses.
Fluid...yes....braided hose...no. RS already has reinforced hoses...IIRC.
