No sound from retrofitted Columbus
Hi All,
I installed a Columbus into a Superb today for another forum member. The car has the 'Sound System' - badge on speakers installed which I assume is similar to, if not the same as Dynaudio? It has amp under the passenger seat, plus an array of three microphones in the headliner.
The Columbus is reporting faults against all speaker outputs in VCDS scan, and there is no sound at all from radio, media etc.
I hope this is just the coding is wrong. I have tried numerous combinations and permutations of sound system type etc in the long coding using VCDS however none of them seem to be correct.
Was wondering if anyone has this setup (Superb with 'Sound System' and Columbus) and could share their coding, or point me towards the right info. I have tried following guides for install in Golf with Dynaudio etc thus far to no avail.
Everything else seems to work: climate control display comes up on screen when changing temp, OPS display works, GPS picks up satellites, MFD shows nav info etc. Just no sound.
Currently running 39xx series firmware, will try a downgrade to 26xx if that helps but I am hoping its just coding...
Thanks in advance.
Edited by kamold
Crisis averted.
The amp seems to have been in some sort of coma.
I didn't change the coding, I just queried the amp in vcds for fault codes and it seems to have woken it from its slumber. Weird.
Anyway glad it's working just annoying it didn't work straight away.
