Cam Belt & Water Pump Service Tomorrow
As per the title, I've finally bitten the bullet and booked my Octi in for cambelt service tomorrow. It was last done at 57k and the car has now done 110K but its due on time frame as it was done over four years ago. I was going to leave it till later in the year but its been nagging me as I seem to have a little bit of noise from that side of the engine (rattley bearing noise) and I cant afford to take the chance of it going any time soon. I'm getting my local independent to carry out the work for me, they did quite a bit of work on my old Siggy and they have all ways looked after me. One of the owners has a BAM engined Seat Ibiza running about 300 bhp so they should know what they are doing with this engine. They've qouted me £265 inc VAT which seems pretty fair to me so fingers crossed for tomorrow.
Howard
Would suggest getting them to do the aux belt and possibly the damper too?
Just phoned them and they said they'll be doing that as well :)
I preffer to do the cambelt and others by myself
Make sure they install a new water pump with steel/metal impeller. There are some ones that have plastic impeller and the impeller cracks
Here is my water pump with plastic impeller
Good luck,
Isaac
The rattling could be the tensioner/damper but as long as they're replacing that you should be ok.
It's great to have the peace of mind that it's all been done - and you've got a good price there too.
Its funny but they actually specified that they'd only fit the metal impeller pump even before I had time to say lol. As said they know they're stuff and I have been very happy with thier work in the past. And it will definitely be a wait off my mind once its done.
This is the damper, isnt part of a cambelt kit.
http://www.vwspares.co.uk/product_info.php?products_id=215
I dont know you guys but when I changed my Timing Belt I got a kit from USA that include all of these:
06B 109 119A (GATES T306) Timing Belt, Gates brand, same exact part as OE
06B 109 243D Timing Belt Tensioner, NTN brand, same exact part as OE
06B 109 477 T-Belt Damper w/included 06B 109 244 roller, NTN brand, same as OE.
06A 121 011T (GEBA 9070) Geba German water pump with steel impeller
050 121 113C (Behr 1.180.87.302) Stock 87 degree Behr German Thermostat with 059 121 119 o-ring seal. (Behr is OE manufacturer) it
06A 121 121C Thermostat housing cover from the VW/Audi dealer (plastic, replace every time you touch it!)
06A 260 849C (GAT DK 060472) Serpentine Belt for cars with air conditioning, Gates brand, Made in U.S.A.!
N 105 167 01 Always-Replace Small OE Motor Mount bolts x2 (torque: 30 lb. /ft. + Quarter turn)
N 102 096 03 Always-Replace Large OE Motor Mount bolts x2 (torque: 74 lb. /ft.)
Isaac
Edited by Turbo_Boss
Isaac
How much did that all cost you m8?
Good luck,
Isaac
There was thread recently relating to this issue,if fitting a waterpump with metal impeller be aware that heat generated by it could possibly make it seize solid doing more damage to engine than one with plastic impeller. Pumps with plastic impeller i believe are designed to minimise damage to engine if things go wrong,hence them being o/e fitment.
Sorry for throwing a spanner in the works but maybe something to think about :-)
