Interior door handle
Just wondering if the interior handle ( the plastic ones used to close the door) can be replaced. The passenger one is a bit loose and not happy with it. Can I buy replacements from somewhere? Is there any sort of an upgrade? Or can I get one of any other car that would fit??
Thanks for the help :thumbup:
If its anything like the fabia's then if I remember right, you can chage them, but if it's loose, then maybe it just needs tightening from the back, think it was a T20 torx used to tighten
There's no Torx behInd there. It works off spring tension and pulls a cable.
If its loose I can only imagine that the spring is knackered. You should be able to buy it separatley, give Skoda a ring
