Pulsating Lights
Hi
I have a Skoda Fabia Clasic Estate 2002 1400cc. It has developed the following fault, when the lights are switched on they periodically start to pulse (even on the reversing lights. This can be annoying when you are driving at night as it also draws the attention of oncoming drivers. Can anyone advise me as to what this problem may be or if you have had simmillar problems with you car and had it repaired etc.
Earth fault somewhere in thw wiring, or water in a light lens.
Had this on a MK1 TDi Octy and it was an earth problem.Don,t know where as it was done under warranty at the dealers.
Thanks for this info. Will have to investigate.
Thanks for this info. I will have to investigate any earth problems.
