Knocking when I press clutch
As title, when I press clutch when stationary both engine on and off, there is a dull "knock" sound. Anyone had this before? Seen a couple of similar symptoms when searching on here but couldn't see if there was a solution.
It's an 06 vrs (petrol).
Just been looking at it again and the noise is more of a clunk if the engine is on and I press/let go of clutch pedal.
probably the dmf.
Not noticed anything erratic, no vibrations etc, just a Single "clunk" when the clutch pedal is pressed. Engages gears fine etc.
Hope dmf is covered on the skoda used warranty!
Edited by thewill
It seem the knocking is contagious. Not only is there a knock when depressing the clutch pedal, there is now a knocking noise when stationary and turning steering wheel from side to side (not turning it hard, just turning it).
Any ideas?
