removing front seats
looked through a few threads there and people are sayin about disconnecting the battery before removal due to air bags in the seats...is this necessary for seats without air bags? i know theres a connection below the seat, is this to do with the air bags?
Not airbags in the seats........but because the seats have a sensor in for detecting the person and there is also a connector which is linked to the seat belt pre-tensioners...and you don't want them going off!!!!!... B)
In theory the airbags and pretensioners shouldn't be active with the ignition switched off, so it's just a safety precaution in case of a malfunction or knackered wiring shorting out somewhere etc.
Personally I would risk it, but then I like to live life on the edge and give health and safety the :finger:
cheers for the info. :thumbup:
I took my drivers seat out - no wires...
M8 spline drive bolts in each corner :thumbup: Should be replaced with new but if carefully replaced to avoid cross-threading, shouldn't be a problem.
Both my seats came out to be scrubbed clean and had no wires at all.
But then i don't have side airbags or heated seats ;)
For future reference is it a M10 or M12 spline to unbolt the seats?
M10 IIRC :)
Ah, I forgot M8 spline is for the slam panel. :D Always getting them mixed up. Sure M10 is the seat one. :thumbup:
