12volt supply
hallo all,
anyone no were i can bring a supply ,fused,for a accessory gadget,needs only 3volt.
thanks
chas.
Hi Chas, First of all where do you want the 3volt supply and at what current, if you are near a cig/lighter socket you can buy adaptors from 'maplin' which have a voltage regulator built in and supply 500ma. cheers - Stuart
Direct from the fusebox?
You can use a (fused) 'power tap' and use either a ignition fed or permanent feed.
I've run power from a couple of empty fuse slots on the fuse box. (DRLs and phone kit) In-line fuse and a spade connector to connect it.
However, I'm not sure you'll easily find a 3volt supply on a 12volt car. (As always, happy to be shown otherwise though)
:thumbs up: thanks for the replies chaps,what i meant to say the unit is fitted with 12v plug in socket and uses 3volt,but i don't want to use the cigarette plug,i think i will use the spare fuse as shown in the photo
Edited by mantiss
