Coolent leak
I've got a small coolent leak, thought it was coming from the temp sender but on closer inspection it is coming from the small pipe that leads from it to the block. Its leaking at the engine end. Question is will I get away with just reseating it or is it a new pipe or could it be what the pipe goes to?
No one had similar problems? I'm wondering if it goes to a plastic connector or something that's cracked. Might have a word with my mechanic that's doing the timing belt and water pump and see what he thinks
