Brakes Arrived!
:D :D :D
My 4 pot Hispecs have arrived!
Hi Spec - Volkswagen Golf Mk4 325mm Billet 4 Conversion Kit
Aluminium Bell Colour - Silver
Brake Caliper Colour - Red
Brake Disc Style - Cross Drilled Rotors
Brake Hose Applications - Stainless steel braided hoses
Brake Pad Applications - Ferodo DS2500
Got to pick them up tonight from my mothers! Will be uploading pictures tonight and getting them fitted this week!
Ordered them 13days ago! so the service is amazing for custom stuff! and for a little over 1k its great!
pics!!!
Sounds like Brakes porn! If i had a good job this is the kind of stuff i'd be buying. B)
Get em fitted and some pics up chap. :)
What wheels are they going under?
Delicious!
They are going under spiders at the moment
Good stuff ;)
Be interesting to know how heavy the whole setup is, and what diameter pistons they have :thumbup:
Disk caliper + pad
is that these mate? :smirk: the mk4 kit or do they change anything for the octys
It's for the mk4 golf but fits octavia too
sweet :smirk: just the matter of the grand then :thumbdown:
8.4Kg
Even with carriers & bolts, well under the 13Kg (iirc) of OEM setup :thumbup:
Don't forget to drill a grub screw hole on the bell, that way you can tighten the disc to the hub, otherwise it'll be a right sod to line everything up when you fit the wheel!
If you can get hold of an old rear hub you can do it easily enough.
Steve :)
Look great :):thumbup:
Replacing bolts with studs so don't need a grub screw. Hopefully getting them fitted tomorrow with the BC racing coilovers!
Didn't replace them with the studs but all 3mm spacers needed as with out there is a hairline gap. Wheel still spins though.
Had an issue bleeding the brakes had to bleed the mc but they are excellent!
Edited by Dan lewis
Very very nice- how do they feel? Or do you still need to wait for them to bed in?
Also....clean your arches! :giggle:
why do some grooves and drill patterns go that way and others the other way like a directional tyre etc??????
had some grooved discs on my golf and they were put that way round
All depends on inner fins. Some suck air in.
They are immense! On the testing 120-30 I unbelievable!!
And fitted under wheels? :)
Edited by Liverpool-Lad
Yea I'll get some pics tomorrow of brakes and lows
Id really like a set of these, did you have to change anything else? Like master cylinder or something?
I heard rumours some kit need it or sumin? I think was something about otherwise the peddle feels difference or goes rite down or something? Something strange lol but i cant remember ..... Sorry im crap
Nope
The only mk.4 platform specific item in the kit will be the carriers and brake line hoses.
