Bolero problem
Hi all
Radio's playing up in all modes,refuses to read SD card (need to check it on the pc, will not read/play cd's or the radio function, and lastly no volume adjustment using both controls i is this a simple home fix, have reset all the mfd defaults to no avail, is it a radio out, check the plugs etc or is it a dealer job?
tony
reboot it, even if that means taking out the fuse.......?
With the Bolero (as I don't believe that is a Bolero shewn above) just press and hold the Setup button to recalibrate radio volumes especially AM. Good luck!
Ca marche!!(that works) - brilliant - thanks for that - now a HAPPY BUNNY - enjoy my music on the move!
Salut
tony
Brill!
Tony,
Aren't you glad you come here?
Off Topic, but what's the weather like for next week? We're going to be in Bayeux for 4 nights from Monday.
Tony,
Just read the post, too late for the brittany / normandie forecasts - i seem to remember talk of a cold day poss 2 next week - will post pm tpomorrow!
On a rly tack if you are going to see the narrow gauge thing by the somme, the is also anpther narrow gauge line at Alkbert(about 10 mls east of Amiens, its a ww1 one wqith a southern USA tank there also least itwas alst year! - The rly station in Albert is also worth a visit, there is a 30's high wing palne in the ticket hall - powered br a renault car engine, renovated and used in the 60's now on permanent display on an ali sculptuere stand - also adj to the station is the nose of a modern passenger plane(think there is quite a large aeronautical industry in and around Albert - the road east to Bapaume also has boards indicating the front its pitifgul really but worth a look!
salut
T
Tony,
Graham
Look at www.meteofrance.com - you can get a region by region 9 day outlook - hope that helps
salut a la beau soleil en finistere
Tony
Merci, monsieur.
A bit warmer than here, with some showers.....hoo humm
