Headlamp Washers
Hi guys and gals,
Could do with a few pointers, I got my VCDS lead delivered yesterday so I decided to scan the car last night and low and behold I think I've found out why I've never noticed the headlight washers working as I got the following fault code:
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005613325
Coding: E18A0F130004140043110D000000000000087F065C000000000000000000
Shop #: WSC 73430 790 00000
VCID: 71ED926768B23BB
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 260308 022 0601
Coding: 00055223
Shop #: WSC 73430
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 030408 046 0204
Coding: 00471077
Shop #: WSC 73430
1 Fault Found:
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 107
Mileage: 50838 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.35 V
ON
ON
OFF
OFF
OFF
Car is an 08 Scout with Xenons, has anyone seen this kind of fault previously? I can only assume that the relay is faulty, does anyone know where this is located and/or have a part no. for a replacement?
Also more worryingly I got the following faults:
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0192
Revision: H16 Serial number: 2500K0832807E2
Coding: E9837F0E0002022303
Shop #: WSC 25066 576 90980
VCID: 34635B7357204E3
2 Faults Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 145
Mileage: 54290 km
Time Indication: 0
Date: 2000.00.00
Time: 12:23:48
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 149
Reset counter: 105
Mileage: 54290 km
Time Indication: 0
Date: 2000.00.00
Time: 18:13:58
I am particularly concerned about the "Control Module Incorrectly Coded", anyone have any ideas?
Many thanks for any help you can offer.
Andy.
Hi,
the first fault could be the easiest to fix, worth checking the fuse for the head-lamp washer as I had exactly the same fault with mine. Worth asking others for the coding for the CAN gateway.
Tim
Hi,
Tim
Thanks Tim, don't suppose you know which fuse I should look at?
Cheers,
Andy.
Hi,
it is fuse 36, in the fuse carrier behind the end panel on the drivers side (see manual page 288) to gain access.
Tim
Andy,
just had a look at the coding and it looks OK compared to mine, but it think it may be useful to put your full scan on the forum incase you have other control modules installed (eg tow bar) .
Tim
Andy,
Tim
Thanks Tim, its a long one but for anyone whose interested here it is:
Tuesday,21,February,2012,20:10:01:29168
VCDS Version: Release 11.11.2 (x64)
Data version: 20120126
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56 62 72 76
VIN: Mileage: 110500km/68661miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 021 SS HW: 03G 906 021 AB
Component: R4 2,0L EDC G000SG 1302
Revision: --H08--- Serial number: SKZ7Z0H4763111
Coding: 0000172
Shop #: WSC 73430 000 00000
VCID: 820F4DABDD14B03
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-614-517-MK60-A.lbl
Part No SW: 1K0 614 517 AD HW: 1K0 614 517 AD
Component: ESP 4MOTION MK60-AT 0102
Revision: 00H14001
Coding: 0023170
VCID: 69DDFA074062C3B
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Z0 907 044 AB HW: 1Z0 907 044 AB
Component: ClimatronicPQ35 120 0600
Revision: 00120022 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 76E7A17B01DC1C3
Coding: 00055223
Shop #: WSC 73430
Coding: 00471077
Shop #: WSC 73430
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 107
Mileage: 50838 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.35 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1X2TK5
Coding: 0020788
VCID: 3D757E57646A8FB
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0101
Coding: 0002042
VCID: 78FBAF430BC86A3
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612036 Serial number: SKZ7Z0H4763111
Coding: 0007402
Shop #: WSC 25066 986 90980
VCID: 397D6A477042B3B
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 145
Mileage: 54290 km
Time Indication: 0
Date: 2000.00.00
Time: 12:23:48
000 - -
Freeze Frame:
Fault Priority: 1
Reset counter: 105
Mileage: 54290 km
Time Indication: 0
Date: 2000.00.00
Time: 18:13:58
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
VCID: 3667617B415C5C3
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1612
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1Z0 035 680 A HW: 1Z0 035 680 A
Component: RNS-MID H04 1004
Revision: AB001001 Serial number: SKZ6Z7H9003099
Coding: 060004000001000300
ASAM Dataset: ------------------------- ------
VCID: 326F5D6B6D34403
3 Faults Found:
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Reset counter: 107
Mileage: 54288 km
Time Indication: 0
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Reset counter: 107
Mileage: 54288 km
Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 147
Mileage: 103963 km
Time Indication: 0
Date: 2000.00.00
Time: 19:17:46
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1204
Coding: 0000758
VCID: 387B6F434B48AA3
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
Shop #: WSC 73430 000 90108
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 81801A085283007F3F02050FC0085F96907C00
VCID: 830148AFC20EB9B
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 73430
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H08 9001
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000758
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000008
VCID: F4E31B7397A08E3
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 107
Mileage: 54288 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 107
Mileage: 54288 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 147
Mileage: 103963 km
Time Indication: 0
Date: 2000.00.00
Time: 19:17:46
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 006 1301
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 37796C7F4656A5B
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0000001
Shop #: WSC 73430 790 08192
End ---------------------------------------------------------------------
Welcome to the magical world of VCDS. The Ross-Tech Wiki is invaluable for information about fault codes - although it doesn't list your first one.
http://wiki.ross-tec...ory:Fault_Codes
Thanks for that Dennis, a little light reading for me then :happy:
Re the headlight washer, definitely check the fuse. This happened on my MkIV Golf a few years ago. I tried to use them when they were frozen and it blew the fuse! I had a similar issue with my Bora when they stopped working and this was down to moisture in the relay fecking it up!
On the other faults, out of Interest, was your Columbus a factory fit, and do you have a Dension or Connects 2 iPod connection? Also whats the radio reception like?
The aerial fault could be moisture ingress into the amplified base of the mast. There are a few threads on here about it. You also get a aerial fault with an aftermarket fitted Columbus as the factory fit has two aerials and aftermarket one only has one, unless an adapter has been fitted to "fool" it into thinking there are two. Again if its an aftermarket fit of the Columbus, it might simply be that the CAN gateway wasn't coded or it might be that it needs the revised gateway.
If an iPod connector has been added, the extra wiring can be problematic and cause wires to get squashed or "nicked". can wires don't like this and you can get faults logged, but no apparent problems.
Sorry if it was factory fit, not much of what i've said will be of use!
Thanks for that Uncle Bulgaria and yes it was an after market upgrade to the Columbus. The radio reception is great on fm but poor on am, is this where the two aerials come in that you mention?
I have no iPod interface but I fitted the Columbus myself so it was never coded to the car although it seems to work fine, what coding should it have? Would this cause the cd changer fault as well? I never noticed a problem with this as I never use it.
Cheers,
Andy.
My Octavia has exactly the same fault codes for the retrofitted Columbus, nothing to worry about. From factory, your car will only have had one antenna -- as said earlier, the Columbus needs 2, one for FM, one for AM. Even with a Fakra splitter installed, you'll get the fault code. The reason your reception is good on FM and poor on AM is that you won't have an AM antenna plugged in. A Fakra splitterwill give you AM radio, but won't get rid of the fault code.
The gateway fault is showing as a not registered status because it has not been told of the upgrade to a navigation unit. -- simply fix. Go into controller 19 and tick box 37.
CD changer fault could be 2 things -- either it isn't plugged into the quadlock at the back of the Columbus, and the Columbus (in module 37 or 56) is coded to say that it should have a changer there, or it may be that the earth pin hasn't been swapped over in the quadlock connector at the back of the head unit. The earth for the CD changer is in a different position on the Columbus from where it is as standard with the Stream, which would have been in your car from factory. Take the Columbus out, and have a look -- the CD changer connector is the blue plug. Match where the cables are in the plug to the diagram on the Columbus.
Your short to ground on the GPS antenna has only happened once, so it's probably happened when the unit was installed.
It's not showing in yours, but you'll even get a fault code of AUX short to ground if you disconnect the ipod/mp3 player or whatever you have plugged in, and leave the leave plugged into the aux socket in the car! The very fact that the plug slides into a socket with 3 bands of metal for contacts means that you cannot avoid momentarilty shorting the system to ground, and this will show up immediately.
Try clearing the fault codes shown, and see which ones return.
Mike
Mike, thanks for that, explains a lot. I will look at getting the Fakra splitter just so I can get 5live on the odd occasion I listen to it.
I will try that coding for the Nav and see if that clears the gateway fault, and aslo take a look at the CD changer earth pin.
To be honest when I put the Columbus in i worked straight off and integrated straight away with the maxi-dot so I assumed no coding was necessary. Of course due to the 20Gb hard drive I never bothered even trying the CD changer.
I cleared the above codes and the washer relay, gateway, radio antenna and CD changer all cam straight back, but sounds like I at least have the first stages of correcting all of these now thanks to the knowledgable people on here!
Edited by Anddenton
A retrofit Columbus may or may not need coding. It all depends on what coding is already in the head unit when it is fitted. For example, a Columbus that has come out of an Octavia with a sound system won't give any speaker output when put straight into an Octavia without, and likewise, one out of a Superb will have the linear equalization etc set for Superb rather than Octy. Best to check that the code is right for your particular Octavia!
Mike
Thanks for that Mike, will spend a bit more time going through all the coding at the weekend.
Edited by Anddenton
OK, with regard to the headlamp washers, I have checked the fuse and it seems fine. Strangely fuse 36 was only a 5Amp fuse (Manual says it should be a 20Amp) Fuse 35 next door was a 20Amp fuse (Anti theft alarm) where the manual says it should only be a 5Amp fuse, so not sure if somebody has looked at this issue before and put the fuses back in the wrong places!
Anyway any other ideas or can somebody tell me which relay to look at?
Many thanks.
Apologies, it was a school boy error, I had counted to the wrong fuse as I hadn't realised the fuse box was mirrored on the drawing on the insert card. Yes it was a fuse in the end. MAny thanks for help on that.
Glad to know you are getting things sorted!
Yep, only fault left now is the radio antenna for which I need to order a fakra splitter (although I believe from an earlier post even this won't get rid of the fault report).
The cd changer was a interesting one, seems an extra section has been added into the wiring loom at some point into which three wires for telemute have been added. I've no idea what these are for as the Bluetooth is an aftermarket kit which doesn't seem to have any effect on the stereo. Anyway the cd changer connections hadn't been carried through the cable extension. The fix was simply to take the cd changer connector block out of the connector at the far end of the extension and plug it into the connector that is directly on the back of the head unit, problem solved (well once I managed to find a cd to test it)
  • 12 years later...
Hi all, I'm getting the same issue on my 05 plate Octavia 1.9 tdi 4x4, but my headlight washers work fine. Any idea what it could be ?
Edited by Leew71
After 12 years since the last post it is probably worth describing your fault in detail as most readers will be new.
