Dash clocks
How do u remove ur dash clocks????
Pull the steering wheel out and down as far as possible.
Remove the trim above the column shrouds that sits below the dash cluster, it's just pulls out.
Undo the two T20 torx screws at the bottom.
Get a thin plastic trim tool or credit card and pop it in the top, be very careful, you need the top to angle down and towards you then the cluster will come out. Undo the black plug on the left and then pivot around, the green plug on the other side needs the pink locking arm moving up first and that will undo.
If I take it out will it need took to skoda or will any lights be on???
You can remove and re install with no issue.
Is there a speedo cable?
No cable. Just the two plugs
Why do you want to remove it??
Speedo is electronic, so no cable.
To look at why my buzzer and idicators o clicking mate
