URGENT HELP MY PASSANGER WINDOW
URGENT HALP NEEDED MY PASSANGER WINDOW SOMETHING HAS SNAPPED AND THE WINDOW HAS DROPPED IVE TAKEN ALL THE SCREWS OUT BUT CANT LIFT THE DOOR CARD OFF THE DOOR AT THE TOP BY THE WINDOW ANYONE PLESASE ASAP
If you have all the screws off the bottom and I think there might be some in the door handle itself and maybe behind the tweeter (been a while since I had to take a door card off!) then its just a case of a good pull. It sounds like it could be a snapped cable if it is there are repair kits for about £20 on ebay
Remove the tweeter blank, there is another screw behind there.
Also, have you removed the handle and the three screws behind there?
Once you're at this point, follow the guide below to get to the regulator.
http://www.briskoda....laries-carrier/
cheers bois must be the tweeter blank and are the bands easy to fit ?
Not too difficult.
Worse thing is usually unwinding the cable if it's wrapped itself around the motor.
My old Polo did this, I nearly cut my hand open on the frayed cable :(
no screws behind the tweeter blank its like its hooked over the top ??
i really dont wanna snap it if i pull it upward it comes up by the tweeter but the rest wont come up grief or what !
There should be a torx screw behind the tweeter?
Also you have definitely remove the three philips screws behind the door handle?
yey ive done it lol but now , taken the motor off and the wire is hanging round the white cog the plate has rivets round it all the way any ideas ??
