Does Fabia II vrs have a timing belt or chain?
well my fiat grande punto sporting, replaced my fabia I vRS, and was was faultless (WAY more reliable than the fabia it replaced) I mapped it at 4,000 miles, and sold it at 110,000 miles, and it NEVER let me down... it was cheaper than the fabia, just as fast, handled better, and was better equipped....
so I would have to say they did a better job than skoda had....
you must have had a bad experiance, ......
Real life comparison.
Fiat Tempra bought with 16 miles on clock
4k Miles - Fuel Pump Failed
18k - Alternator
19k - Power Steering Pump
23K - Water Pump
25k - Exhaust Pipe
28K - Manual choke cable snapped
30K - Belt Tensioner
30K - Front discs ruined - wear indicator circuit u/s
30k - Cover gaskets knackered - leaking oil all over engine
35k - TDC Sensor
36k - Belt Tensioer (again)
48K Power Steering Pump (again)
52k - Belt tensioner again
55K - gear lever connecting rod siezed
58K - no lights - earthing stud missing
60K - alternator.
70k - clutch replaced
etc.
On top of that, the Wiper motor kept blowing fuses and I had to change one bulb or another every couple of months.
VAG cars:
VW Passat
50K Miles - Window lifter u/s
Otherwise fault free. Still had original clutch and exhaust pipe and had only changed discs and pads once in over 100K Miles
Fabia Mark 1 vRS - 30k miles fault free
Fabia 3 Estate - 36K Miles with only two faults - airbag igniter and glowplug fault.
My conclusion - Fiats are designed by morons who use spaghetti and olive oil as their most robust components
VAG - properly designed and tested pieces of engineering
Recent JD Power Survey listed the Punto as the worst car out of 85 surveyed
Fiat aftercare - they didn't want to know!
18k - Alternator
23K - Water Pump
25k - Exhaust Pipe
35k - TDC Sensor
60K - alternator.
etc.
VAG cars:
VW Passat
lol... at least I know understand your attidtude ;)
fiat have turned it around with the cars (unlike the dealers, which by all reports are still rubbish, but mine was a small family owned place that was very good indeed) the tempra was "back in the day" when you could expect everything electrical to go wrong with a fiat, the electrics are now done by BOSCH ;)
things can change, I'm not takinging the mick when I say mine was faultless for over 100k and miles better than the previous skoda?
can you at least admit, I have had a completley different ownership experiance to you?! lol... AND that just because you have bad experiance, doesn't mean we all have?
No belt?
Camshafts are chain driven
Alternator, water pump, AC compressor are driven by a belt
Supercharger is driven by another belt.
Hope that clears it up..lol
So basicly no belt changes on service intervals... only by VHC (Vehicle health Check)
Want to know "what drives what and how"?
From a recent post about a week ago: http://www.volkspage...ssp/SSP_359.pdf
Interesting if you're that way inclined.
Edited by Lee
