Rear wheel bearing replacement
Could someone give me a run down on how to change a rear wheel bearing (lost my haynes) and provide torq settings pleaseeeee! :blush:
Hi Robbie
Is that rear hub removal and refit ?
chock wheels
remove drum or discs
remove dust cap from centre
unscrew hub nut, will need torque bar, recommended will need renewing
use a puller to pull hub/bearings from stub - care with ABS sensor ring
check everything for good order
lubricate suitably, drift the inner race on the stub, use a large socket if necessary using only the inner race
screw new nut on and torque
check or replace dust cap, tap carefully back into position
refit the rest
A Haynes style run down
With the help of a friend disconnect the battery
With the help of another friend or the same friend if they are still about jack the vehicle up and support on axle stands
The friend has now got bored so your on your own, remove the road wheel.
Unbolt brake carrier from rear axle, 2 x 8mm allen key bolts, slide caliper and carrier from disc. If a lip on the disc stops it coming off go straight to next step
Remove disc retaining screw and disc (if caliper could not be removed slide this off with the disc still attatched)
Your friend has returned, not with tea, send him back to kitchen.
Knock off centre cap and undo 30mm centre nut, withdraw hub unit. Replace hub unit and fit new nut. Tighten up nut to specified torque.
Refit all components in reverse of above.
Slap friend for taking so long with the tea.
seems easy enough, i was thinking it was a case of take it off and throw another on. Whats the torq setting for the center/hub nut?
Can't remember off hand, could be 75nm but I'd get someone with a manual to check.
thanks!
Very close.
  • 3 months later...
