Bolero Mix Not Random
Hi, I have put a lot of album tracks into one folder so the mix would work. But when I play the folders in Mix mode. One track is played from each album starting with A (Artic Monkey) and progressing through the alphabet and then going back to A and playing the same tracks as before?
Any thoughts. How do I get it to play the tracks randomly?
If you want true mix mode across all the folders, stick a single MP3 file at the top of the SD card outside all the folders and play that first. Then in theory at least it should pick random files from all over the cards folders after that track has finished playing.
IIRC there are 2 mix modes and you need to select the appropriate one for mixing across folders for this to work.
