Arghh help! Wind deflectors!
Hello fellow skoda owners i seem to have run into a bit of a problem... I recently bought a vrs and it already had team heko wind deflectors installed however the passenger side rear deflector seemed to be abit loose and eventually fell off. How do i fit the deflector back on? Do i need special adhesive to stick it back? I have no idea so please advise on the best possible solution.
Thanks in advance
Stick some glue on the white tabs and just shove it back in :)
There is mena b 2 metal clips that slide up into the window with the deflector
Hi m8
I've got the same deflectors I didn't like the metal clips so I got the double sided tape that you use to stick number plates on .
You just need to cut it to fit along the edge and stick it back in window .
Mine have not moved
Regards Whoosh
Hi m8
Mine have not moved
Regards Whoosh
Where do i get double sided tape from lol?
Hi m8
Your local car spares shop or halfords
Regards Whoosh
