Front wiper blades removal
Hi all bit of a silly question but how do you remove the front wiper blades as I need to change them??? Thanks
from what i remember, pull the arms away from the screen,rotate the blades about ninety degrees and the blades will slide off the arms.
Don't pull the arms.
Put them in service position. Do that by turning ignition on, then off, then press wiper control down and release it. Wipers then go vertical and stop. THEN they can be pulled off screen, and blades rotated and drawn off the pivots.
cheers mate thanks for that i couldnt for the life of me figure out how they come off lol :rofl:
And make sure you put your wipers back down before turning them on again or you will be having the bonnet resprayed.
