fault code p2185?
my engine warning light has came on and the obd scan vame up with this? any ideas?? all the.hoses are ok and no leaks.
engine coolent temp is high it says. but sits at 90 like normal same we the engine oil
Description of OBD II Fault code P2185
ENGINE COOLANT TEMPERATURE (ECT) SENSOR 2 CIRCUIT HIGH VOLTAGE
Possible failuer of OBD II Fault code P2185
Engine coolant temperature 2 (TW2) sensor harness open
Engine coolant temperature 2 (TW2) sensor GND(SG2) line open
Engine coolant temperature 2 (TW2) sensor malfunction
I'm £100 lighter today.
Apparently there was "impact damage" and its caused a sensor to fail so its been replaced. Can't think of any thing I've done that would of caused that.
Drove on some grass at the local park in and some of the dips were pretty big but I was going slow. Scraped a couple of times but didn't think it was that big a deal as it was just like a big speed bump, but grass.
Must of caused it though, gutted to be fair but oh well. :(
At least it has been sorted.
yea thats true. could of been a lot worse
