Skoda/Audi
Hello All
Yet another q from me on a topic, this time not specifically related to Octavia
A friend of a friend has a 2009 Audi A4 1.8 T FSI manual saloon
I checked the horsepower, torgue etc of this Audi and it seems to be the exact same as the 1.8 TSI in the Octavia
And when I speak of the 1.8 TSI Octavia, I mean the 2010 facelifted model
I know the 1.8 TSi Octavia has a timing CHAIN instead of a timing BELT which is good
&--#62; Does anybody know if the Above Audi A4 has a timing belt or chain
&--#62; Is the Audi 1.8 T FSI more a less the same engine as the Octavia 1.8 TSI but just a different name
I know this is not an Audi forum but just thought id ask this question anyways
Edited by obi604
It's the same engine.
The whole VAG group share engines. The oly difference being the special models like S3 and Edition 30 Gols have a slightly different 2.0T.
thanks for reply, all very confusing with the tsi, tfsi, fsi etc.
So the 2009 Audi A4 1.8 T FSI manual saloon definitely has a chain then ?
As the friend of a friend is saying its a belt
Definitely a chain. They are the same engine, just badged diferently.
Just don't tell the Audi salesman :giggle:
Vorsprung Durch Skaudi Engine !
hahahahahha :rofl:
Out of interest, I actually rang an Audi garage during lunch ( about a 2009 1.8 TFSI manual ) and inquired and the feckin saleman told me it was a belt
What the hell is wrong with these salemen, they dont know their stuff at all !!
Audi - four rings on the bonnet; four grand on the price!
Are you guys sure it not a belt? What's the Audi's engine code?
I have an Octavia 1.8 TSI... it is a Chain not a belt...
1.8 R4 16v TSI/TFSI 88-125kW (EA888)
identification parts code prefix: 06H, 06J; ID codes: BYJ engine displacement & engine configuration 1,798 cubic centimetres (109.7 cu in) EA888 inline-four engine (R4/I4); bore x stroke: 82.5 by 84.1 millimetres (3.25 in × 3.31 in), stroke ratio: 0.98:1 - 'square engine', 449.6 cc per cylinder; compression ratio: 9.6:1, 88 millimetres (3.46 in) cylinder spacing cylinder block & crankcase GJL 250 grey cast iron; 33 kg (73 lb), die-forged steel crankshaft with five 58 mm (2.28 in) diameter main bearings, two toothed chain-driven counter-rotating balance shafts suppressing second degree free inertial forces and oil pump, horizontal-baffled oil sump cylinder head & valvetrain cast aluminium alloy; four valves per cylinder, 16 valves total, low-friction roller finger cam followers with automatic hydraulic valve clearance compensation, toothed chain-driven double overhead camshaft (DOHC), continuous vane-adjustablevariable intake valve timing aspiration hot-film air mass meter, cast alloy throttle body with electronically controlled Bosch E-Gas 'drive by wire' throttle butterfly valve, plastic variable length controlled intake manifold with charge movement flaps controlling combustion chamber air movement, BorgWarner K03 water-cooled turbocharger incorporated into cast iron exhaust manifold, sandwiched central front-mounted intercooler (FMIC) fuel system fully demand-controlled and returnless; - fuel tank–mounted low-pressure fuel pump; Fuel Stratified Injection (FSI): single-piston high-pressure injection pump driven by a four-lobe cam on the exhaust camshaft supplying up to 150 bars(2,180 psi) fuel pressure in the stainless steel common rail fuel rail, four combustion chamber sited direct injection sequential solenoid-controlled six-hole fuel injectors, air-guided combustion process, multi-pulse dual-stage injection during the induction and compression stroke with homogeneous mixing, stratified lean-burn operation with excess air at part load, 95 RON unleaded ultra-low sulphur petrol ignition system & engine management centrally positioned longlife spark plugs, mapped direct ignition with four individual direct-acting single spark coils; Bosch Motronic MED electronic engine control unit (ECU), cylinder-selective knock control via two knock sensors, permanentlambda control exhaust system cast iron exhaust manifold (with integrated turbocharger), close-coupled and main catalytic converters - both ceramic DIN-rated motive power & torque outputs, ID codes 88 kilowatts (120 PS; 118 bhp) @ 4,000-6,200 rpm; 230 newton metres (170 lbf·ft) @ 1,500-3,650rpm — Audi B8 A4, SEAT Exeo 118 kilowatts (160 PS; 158 bhp) @ 4,500-6,200 rpm; 250 newton metres (180 lbf·ft) @ 1,500-4,500 rpm, 165 N·m (122 lbf·ft) from 1,000 rpm — CDAA Škoda Yeti 112 kilowatts (152 PS; 150 bhp) @ 4,300-6,200 rpm; 250 newton metres (180 lbf·ft) @ 1,500-4,200 rpm, 165 N·m (122 lbf·ft) from 1,000 rpm — CDAB Škoda Yeti 118 kilowatts (160 PS; 158 bhp) @ 4,500-6,200 rpm; 250 newton metres (180 lbf·ft) @ 1,500-4,500 rpm — Audi B8 A4, Audi A3 Mk2 (8P), Audi TT Mk2 (8J), SEAT Exeo 125 kilowatts (170 PS; 168 bhp) @ 4,800-6,200 rpm; 250 newton metres (180 lbf·ft) @ 1,500-4,800 rpm — Audi A5 125 kilowatts (170 PS; 168 bhp) @ 3,800-6,200 rpm; 320 newton metres (240 lbf·ft) @ 1,400-3,700 rpm — Audi B8 A4 (2012-), Audi A5 applications Audi TT Mk2 (8J), Audi 8P A3, Audi B7 A4, Audi B8 A4, Audi A5, SEAT Leon Mk2 (1P), SEAT Altea XL, Škoda Yeti, Škoda Octavia Mk2 (1Z, Ming Rui), Škoda Superb Mk2 (3T), VW Jetta Mk5/Sagitar, VW Passat B6, VW Passat CC references
Yup and there`s still plenty of snobs who will pay four grand just to get the four rings...............overpaid muppets :rofl: :rofl:
