Are these correct?!
OK, I realise it maybe tough from just a picture, but there are some awesomely informative people on here, and I am hoping you know! I want to put the standard springs back on to my vRS (2004), but haven't got my old springs. I have seen these on eBay, but want to make sure that they are correct before splashing out.
http://www.ebay.co.uk/itm/Skoda-Fabia-VRS-Mark1-2005-Front-and-Rear-Coil-Springs?item=220998059502&cmd=ViewItem&_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D2%26po%3DLVI%26ps%3D63%26clkid%3D7621581853714188009#ht_451wt_160
I sent a message to the seller, and he has said they are the vRS specifications, but I want to see if I can get confirmation from the knowledgeable folks on here!
They look legit but the only way to be 100% sure you'd need the part code so someone can cross check them on etka.
Thanks...i have sent a message asking for the part number
The seller has said there is no part number on the springs, just the colour coding that is visible in the pictures...
Hmmm in that case I can't really help you as I'm not sure either way. Sorry.
There's no part numbers on my original springs but the fronts have 3 red dots and 1 orange dot. The rears have 2 white, 1 blue and 1 orange dot, hope that helps :thumbup:
From the picture on the advert it looks like those are original springs put into an after market spring box
Likely he's taken the OEM's off replaced with Eibach loweing ones and stuck the OEM in the Eibach box (much in the same way that my full OEM springs and dampers arrived in a Weitech coilover box!)
looks legit to me
thanks for that...so that colour coding is correct?! I want to make sure I am not going to spend a silly amount on something that is incorrect!
Wabey - ive PM'ed you.
Mr Wabey Sir, may I ask where abouts you are, reason I have two sets standard Fabia Springs in the Shed. These are genuine Fabia VRS, off FP07EVV and YR56YRS both fitted with Eibachs, the first now sold. If you are near give me a chance to look in the Shed but should still be there,
I've got a set up in the loft. I'll see if I can get to them to look at.
