Correct OBD2 cable for vcds
Hi all, I have downloaded the vcds lite and installed it to my laptop, I have already got a usb elm327 OBD2 interface but can not get the software to find the interface so I`m guessing its not compatible with vcds, so could any one of you point me to the correct one that me be on fleabay many thanks
it was suggested to me to get this one
http://www.gendan.co...uct_VAGUSB.html
cleared my airbag light in a jiffy. my mate had given me a fleabay one that he got. never worked once. worht the money imo, well built.
hope that helps.
Dave
oh and make sure it's on com port 1-4. anything else wont work.
hope that helps.
Dave
Many thanks Dave
Did you have the cable plugged into the car when you were searching for it? If not then try again with it in the car as I believe they need to be powered to work. When I plug my cable into the car it has a blue light in it that comes on then it gets detected on the USB bus ok
HTH
The ones that use ELM chips will definitely not work.
HTH
Yes thats what I did but with no joy, will invest with the one pointed out to me then problem sorted
