Headlight switch
Hi all possible common fault but here goes over the last week or so my headlight switch decides to turn rear fog on with out pulling switch out two clicks switch buggered? Or a poxie fuse? Lose connection? Cheers
Well the switch is easy to take out and have a look. Push the switch in and at the same time turn to the sidelight position. A good wiggle and it should come out.
Thanks i fo knw its easy to remove i ment loose connection inside as the plug is a multi type jobber cnt see tht being jus loose enugh to cause this probs shud of been clearer
