Faults
Usually what happens is the rivits holding the pump together fails, the fix is to drill them out and fit bolts instead
Sent from my GT-I9100. Not a Crapple!
Thanks for the reply, doesnt sound like too tough a job at least and little cost :)
  • Replies 50
  • Views 5.5k
  • chicken_eyebrow
    chicken_eyebrow
    Yep that's the part. Make sure they offer a guarantee though as those ebay coolant sensors don't always work. Genuine part is £29 from a dealer. The first fault does sound like a MAF issue, I would c
  • chicken_eyebrow
    chicken_eyebrow
    Sensor/sender same thing. You should really replace the U-shaped plastic clip and rubber o-ring seal that hold the sensor in place (another few quid from a dealer) but it looks like that ebay one com
  • chicken_eyebrow
    chicken_eyebrow
    A knackered Coolant Temp Sensor can affect your fuel efficiency because if the ECU thinks the engine is cooler than it really is it injects more fuel. Mine was down by about 3-5mpg with a dodgy sensor
