crank sensor
hi guys took my mk1 octy vrs for scanning today came up with 2 faults one being the brake switch and the other being the crank sensor so i am told i think the code was g28 and it was intermittant was wondering if any of u guys no how much i could expect to pay for a genuine one of these plus the amount of labour i should be loooking at paying want to make sure i am not being overcharged by the garage all help is much appreciated
forgot to add if anyone has any links to where i can get one from and is 80 pounds for the sensor and 50 pounds for an hrs labour about right as i also been quoted 10 pounds for the brake switch and 30 mins labour 25 pounds
Edited by sav26
any one any ideas :(
G28 is the engine speed sensor. What was the fault code?
unsure of the fault code all i saw pop up on laptop at the garage was g28 and then told it was the crank sensor
If G28 fails the car won't start. Good indication of that being faulty is the rev counter won't move when cranking.
However if it's starting ok it might be worth just keeping an eye in it.
been having problems starting the car especially in the wet weather have to keep cranking it giving it a pedal full of gas and it goes eventually does that sound more like a speed sensor as opposed to a crank sensor
