EPC light plus Engine management light
Driving today i was just about to set off from a junction and my EPC light came on i had loss of power could not go more than 10 mph so pulled over turned off. Then restarted light went off all ok about 5 miles later stopped at traffic lights same thing happend but this time engine management light came on as well switched off and on again just engine management light on and now stays on. Anybody any ideas thanks. Skoda assistance coming tomorrow with skoda tec repairer
hi Briskodian,
I had a similar thing happen to my VRS a few weeks ago, the skoda assist guy ran a diagnostics and it was the wires to the fuel solenoid pulling the connector. He straightened the lead/wire to take off the tension and that sorted
it out. It was causing too much fuel to be fed to the engine. I hope this helps? Ron.
I will post findings tommorow
Said it needed turbo shim and update. He is going to do it at my works tomorrow. The turbo has run in and to much air is causing back presure so sets off EPC engine mangement as exhaust gases wrong the shim lits more air through
Woooooo that's where I'm at... Waiting for Skoda Assist :'( only had it back 8 hours...
