Trailer towing:- B and B+E licence rules explained
I have extensive knowledge on this issue and already have a trailer towing clinic HERE as well as many other sites.
I use the above to demonstrate that I have not joined this site to spam etc but simply to help others understand the rules which the Govt sites do not seem to explain very well.
Trailer MAM means the maximum weight the trailer can be when fully loaded (weight of empty trailer plus weight of load)
Trailers over 3500 kgs plated MAM weight come under different rules which is why all the trailers towed by B class vehicles , those of 3.5 tonnes and under, are not plated at more than 3500 kgs or 3.5 tonnes MAM
Trailers without plates use the total of the TYRE LOAD RATINGS to determine the MAM
A rating of 66 on 4 tyres would give a MAM of 1200 kgs.
Vehicles in the B licence category will have the following information on a plate in the vehicle, in the handbook or on the V5 form.
Information can also be found on many internet vehicle specification sites.
Unladen or Kerb weight - although there is a slight difference in the two it is not that much
GVW - the max weight the vehicle can weigh when fully loaded
GTW - the max weight the vehicle and trailer can ACTUALLY weigh when added together. This does not refer to the total of the vehicle GWV and trailer MAM weights.
Towing capacity - this is the ACTUAL weight that can be towed by the vehicle - it does not mean the trailer MAM weight.
None of the above weights must be exceeded
Some vehicles have a GVW, a towing capacity and a GTW. In such a case the GTW takes priority over the GVW and towing capacity when added together
FOR B+E LICENCES
Where a towing capacity is listed then this would be a legal example:-
CAR has GVW of 2000 and a towing capacity of 1800
TRAILER has a MAM of 3500 and an unladen weight of 1000
The trailer can be loaded with a maximum weight of 800
Where there is not a towing capacity listed then the GTW is used
GTW minus the GVW does not give the towing capacity unless the vehicle is fully laden
EXAMPLE: -
VAN has GVW of 3500 and GTW of 6000
TRAILER has MAM of 3500
The van and trailer can weigh 3000 each and be legal
FOR B LICENCES
The Gov sites are not that good at explaining this so I have managed to find a simple way of determining whether a driver can tow something on a B only licence -
To tow over 750 kgs with a B licence you need to say NO to the following:-
Is the plated MAM of the trailer more than the UNLADEN/KERB/EMPTY weight of the towing vehicle?
Does the GVW of the towing vehicle plus the plated MAM of the trailer add up to more than 3500 kgs?
Is the ACTUAL weight of the empty trailer and its load more than the listed towing capacity?
Example of legally towing over 750 kgs with a B licence - made up figures but not that far from what can be found....
Towing vehicle -
Unladen/empty/kerb = 1500
GVW = 2000
Towing capacity = 1800
Trailer -
Unladen/empty = 800
MAM = 1500 (Perhaps originally a 2000 MAM but downplated by manufacturer so it conforms to B licence towing)
Load trailer with 700 max
Reasons it is legal for towing on a B licence -
The 1500 MAM of the trailer is not more than the 1500 unladen/empty weight of the towing vehicle
The 2000 GVW of the towing vehicle plus the 1500 MAM of the trailer is not more than 3500
The towing capacity/actual weight being towed does not exceed 1800
SUPERVISING A B+E LEARNER
In April 2010 new rules were introduced for those supervising certain learner drivers but they only affected those supervising VOCATIONAL categories such as C1 C1+E D1 & D1+E where the supervising driver had those categories given to them for free when they passed a pre 1997 car test.
They do not affect those with a pre 1997 B+E licence who wish to supervise a B+E learner.
The usual rules apply when a learner is driving -
The supervising driver must be aged over 21
The supervising driver must have held a B+E licence for at least 3 years
L plates must be fitted to the front of the vehicle and the rear of the trailer
Correct insurance for a B+E learner
Caravan weights work on a slightly different system as they take into account the recommended (not legal) 85% towing rule
I hope this helps those who are unsure of the rules
The B only licence category DOES allow you to tow trailers BUT there are weight restrictions.
RULE 1 - The gross plated weight of the trailer (MAM) cannot exceed the vehicle kerbweight.
RULE 2 - Also, the sum of the vehicle gross plated weight (GVW) and the trailer gross plated weight (MAM) cannot exceed 3500kg.
Examples:-
Vehicle 1200kg kerbweight, 1700kg gross plated weight (GVW) = maximum trailer gross plated weight (MAM) 1200kg SEE RULE 1
Vehicle 1500kg kerbweight, 2000kg gross plated weight (GVW) = maximum trailer gross plated weight (MAM) 1500kg SEE RULES 1 & 2
Vehicle 1800kg kerbweight, 2300kg gross plated weight (GVW) = maximum trailer gross plated weight (MAM) 1200kg SEE RULE 2
The weight which can be loaded on the trailer is the trailer gross plated weight (MAM) minus the trailer unladen weight
Trailer gross plated weight (MAM) 1500 with unladen weight 900 = a maximum load of 600
The listed maximum towing capacity for a vehicle must not be exceeded - that is actual weight not plated MAM weight
All B licence holders have a B+E provisional on the paper part of their licence
That means they can tow a B+E combination either loaded or empty and on a motorway providing they adhere to these rules:-
Supervising driver must be age 21+ and held B+E for 3+ years
L plates on front of vehicle and rear of trailer
Correct insurance for B+E learner - check with current insurer
The B+E test
No medical or theory test required
Read a number plate from a certain distance
- usually 5
The next three can be in any order:-
VIDEO - Reversing Exercise (old measurements) - done in test centre grounds if test conducted from practical test centre - some tests are now being done from training school grounds
One hour road drive - includes the independant drive and is done virtually the same as the basic car test
DISCLAIMER - I have no connection to any companies which may be featured in those videos
Edited by ROG.
Please post with this info if you want me to answer a specific query - weights in kgs please
LICENCE
B or B+E
VEHICLE
Unladen/kerb =
GVW =
GTW =
Towing capacity =
TRAILER
Unladen =
MAM =
This was all discusted a while back but could not get a proper answer from the dlva's website,
This is something am quiet interested in doing as I was a year to young to get automatic entitalment and want to tow my track car with my dads van when i eventually get it done but will be over the 3500kg limit altho i am no stranger to towing a trailer just under the 3500kg limit
The DVLA website is not written in the best way possible and many myths have grown up over the internet in the last few years aroung these issues which is why I made an in-depth study and came up with a few others ways of putting the rules without changing them
A few common myths/errors -
Drivers add up the actual weights for the 3500 B towing limit
Drivers add up the kerb weight and the actual trailer weight for the 3500 B towing limit
The MAM of the trailer cannot be more than the vehicle towing capacity - thats a very big internet myth!!
Some B+E training schools state that pre 1997 B+E licence holders cannot supervise B+E learners - that is either a genuine mis-understanding of the April 2010 law changes or they want more work for themselves......
Hiya Rog, I have a cat B licence, a Toyota Corolla 2L d4d, with a GVM 1780 and a towing capacity of 1300, the caravan I want to tow has an unladen weight of 750kg and a mam of 1200 is this legal?
Am I right in think I can tow a caravan with a mam of up to 1300 ( i.e. the towing capacity of the car? )
Thanks, 1.4 tsi
Hi rog have never been able to get a proper answer out of my company regarding this.
My work transit is 3.5tonne can tow 5.5tonne the van normally weighs in around 3tonne, we have a tri axle car trailer around 500kg in which I often have steel pipe on.
I have b+e done the test. Is it legal to tow when max weight is over 3.5tonne without a taco.
Cheers Pete.
Cheers Pete.
The transit has a GVW of 3500 and a GTW of 5500
It cannot tow 5500
The 5500 is the maximum actual weight of both van and trailer when put on a weighbridge
If you are going more than 50 km from base then that will need a tacho and be under EU regs 561/2006 if any trailer is towed by it as the possible MAM is going to be over 3500 kgs
An exemption from EU regs exists for vehicles or towing combinations where the maximum possible MAM is under 7.5 tonnes and no journey goes more than 50 km away from base
If the goods carried on the van or on the trailer are not the property of the company then that also requires a full O licence
If the goods carried do belong to the company the it only requires a restricted O licence if the trailer is over 1020 kgs unladen
Thanks, 1.4 tsi
SPECS FOR YOUR CAR - LEFT COLUMN
LICENCE
B or B+E = B
VEHICLE
Unladen/kerb = 1385
GVW = 1780
Towing capacity = 1300
TRAILER/caravan
Unladen = 750
MAM = 1200
Perfectly LEGAL for B licence towing
Reasons -
GVW 1780 + MAM 1200 = 2980 which is well under the 3500 maximum
MAM 1200 is less than the vehicle 1385 unladen/kerb
The max towing capacity is safe unless you overload the caravan by more than 100 kgs!!
PS - missed answering your last query .....
The LEGAL maximum trailer MAM or caravan MPTLM for this set up on a B licence is 1385 kgs BUT it must never be loaded to an actual weight of more than 1300 because of the towing capacity
SAFETY is a seperate issue when towing a caravan - it is recommended that inexperienced caravanners do not at any time have the actual weight of the caravan at more than 85% of the actual weight of the towing vehicle
Kerb & MPTLM weights are often used for the above as they are constant weights but in reality it is the actual weights which matter
Edited by ROG.
Hi Rog.
Brilliant little topic you've started!
I've got a question, regarding towing my race car on a B licence.
Tow car is a Volkswagen Passat 2006.
Looking at Parkers it looks like GVW is 1648kg and braked towing capacity is 1800kg.
What weight of trailer does this allow me to tow?Kevin
Hi Rog.
SPECS I think you got kerb & GVW mixed up
LICENCE
B or B+E = B
VEHICLE
Unladen/kerb = 1648
GVW = 2060
Most car transporter trailers are about 500 kgs so I'll use that as an example figure
TRAILER
Unladen = 500
MAM = 1440 (MAX)
LOAD/RACE CAR 940 kgs (1440-500=940)
The trailer cannot be more than 1440 MAM because 1440+2060=3500
1440 is less than the 1648 kerb so thats ok
Also its well within the 1800 towing capacity
Trailers can easily be downplated by contacting the manufacturer and costs nowt or very little
Edited by ROG.
Wonderful thanks for your help
  • 4 weeks later...
Could you help me to work out the maths on a towing matter please:
Octavia 2004, the plate under the bonnet has following info on it:
1810 (which I assume is max car weight?)
3110 (max train weight?)
1- 1000
2-1000 ( weight limit on both axles?)
_____________________
500kg - unsure? - max unbreaked trailer maybe?
I ask because I am trying to work out if I can tow a car on a trailer with my 2004 octavia vrs within the law, or whether it over loads the legal limits. I have HGV C+E and therfor B+E on license.
The car I wish to transport is 1100kg - 1187kg (according to stats)
The trailer I would hire weighs 395kg approx with a max payload of 1500 kg
From what I worked out my car can only tow MAX 1300 KG so would I be right in assuming that this particular load would be too heavy.
Rob.
Octavia 2004,
You are correct - too heavy - cry!! - LOL
You make my job easy because you have all the correct and necessary info
Firstly the LOWER figure of the trailer MAM (1500) or towing capacity (1300) needs to be used so in this case it is 1300
We now deduct the unladen trailer weight (395) from that 1300 figure and get 905
905 kgs is the max we can load onto that trailer
If you were to get a towing vehicle with a bigger towing capacity (1500+) then it is still not likely to be legal because the 1500 trailer MAM minus the trailer unladen weight of 395 only leaves 1105 kgs for the load
You need a bigger towing capacity vehicle (1800+) and a bigger MAM trailer that is not too heavy when unladen - perhaps a trailer that is 500 unladen and 1800+ MAM leaving a load for the trailer of 1300 kgs - the trailer MAM can legally be more than the towing capacity
Hi ROG,
I asked at work about how we get round the tacho rules when going 50k with a heavy trailer and aparently it doesn't apply to us because we are a registered charity.
Any truth in that?
Hi ROG,
Any truth in that?
Exemption -
Vehicles or combinations of vehicles with a maximum
permissible mass not exceeding 7.5 tonnes used for the non-commercial carriage of goods.
The 50 km rule has nothing to do with the above - that applies to the commercial carriage of goods
So if a charity (non commercial) has a vehicle and trailer combination where the totals of the vehicle GVW and the trailer MAM do not add up to more than 7500 kgs then it is tacho exempt
The tacho rules are for those in commercial competition with each other
Excellent thread. Can I suggest it get's pinned?
  • 1 year later...
On 19/01/2013 a few licencing changes occurred
The kerb weight rule for B licence towing was revoked
The extra rule for B licence towing of a trailer over 750 kgs MAM is
The vehicle GVW added to the trailer MAM must not total more than 3500 kgs
GVW and MAM have the same meaning - the legal maximum weight something can be when fully loaded
Another change which will affect virtually nobody ....
Those that pass both B and B+E after 19/01/2013 will be limited to a trailer MAM of 3500 kgs
That effectively gives a maximum total possible MAM of 7000 kgs
