double din unit and skoda boot changer work together ?
Looking at the spec I don't think you'll be able to control your CD changer from that, but with a USB input on the front you can load a massive amount of music onto a flash drive and you wouldn't miss your CD changer. However, it doesn't look like you can change the illumination on that stereo so it will stick out like a sore thumb, especially at night, and you'l need a new fascia or adpater to fill in the gap (the Skoda double din stereo front is bigger than a standard double din unit).
Nope, the only thing that can control the boot changer are OEM Skoda headunits. If you go aftermarket then you will lose use of the changer.
thanks all
