help needed with ignigition
Can some one point me in the right direction.
I am going to be fitting a nokia bluetooth unit (which i got for free from work) to the car at some point over the bank holiday weekend and need to connect a wire to the the ignigtion can any anyone tell where the best place is to find the wire (pictures would be good)
To connect to a switched live you can insert a spade crimp connector into (position 8?) a free spur of the fusebox. Provided the wire is fused then it will be fine. Alternatively, if you want to do it correctly, remove the fusebox and add a repair wire (available from the dealers) to a switched live position.
Thats brilliant thanks
