Best camber setting for octavia vrs
Put set lowering springs on octavia vrs 2008 model and back car skipping all over road rear wheels camber sitting at minus 2.5 both sides a bit toouch negative camber for my liking any1 no the best setting for rear camber
Hi baz192 , I have a 2009 vrs fl , and I fixed eibach springs which lowered the car 20mm all sides and I drove it for about 250km to give little time for the springs to set. Then I done the wheel alignment and I can show you the reports both before and after . Much better rear side 0•03'
Edited by Aj1974
My read out just before a slight tweak to make it perfect:
Is the readibgs from hunter at the bottom?? I left mine for about month and then had look
Set toe out front to 0, rear toe to 0 and rear camber to minus 0.6
That will create inside tyre wear. I would suggest in range between -1.1 to -1.5 deg in neg camber depend on how aggresive driver you are. Toe set between +0.3 to +0.6 on each side accordinly. That will create good grip in corners and a little bit positive toe will compansate for negative camber so your tyres will last longer.
