How To: Forge Quick shift plus Verdict linkage bracket solid bushes
Thought I would post this in techi section as it was deep in the vaults on the forum
Pic of the standard VRS gear shifter and linkage
Forge Short Shifter with the 3 optional fitting adapters(depending on which one you have fitted to the car)
Difference between the 2 gear shifters
Original shifter removed
Forge short shifter fitted and in place
Easy job to do and happy with results, Gear shift is a lot less gear throw
Next was the Verdict Motorsport gear shift bushings
http://www.verdictmo...roductCode=0100
I heard about these whilst browsing the VW forums and also our Rob's website as he has these fitted. Ordered from this US website at approx $22 did not break the bank so I gave it a go.
Can see the original rubber mountins on the left verses the solid Verdict mountings on right.
Removing the originals is easy, I memoved the selector cables off the gear linkinage arm as i was replacing that with the forge and was going to do a linkage adjustment anyway. Then I just undid bolts and lift bracket up.
removed the original rubbers
Placed in the verdict replacements
bolted down
Then I reset the gear box linkage
good vid here which is helpful.
http://www.youtube.com/watch?v=tp9ggefOjAE
i see the forge short shift does away with the counter weight,does that make a differance? I have a hpa on mine and that looks standerd apart from the diff pivit placements(20-40% reduction)
  • 4 weeks later...
really helpful vid too
http://www.awesomegt...-6speed-my02-05
are these the ones for the mk1 Vrs? i presume so but i have a habit of ordering the wrong parts.
My gears keep unaligning themselves
That's the one's :thumbup:
think i may get these on order then. gears are behaving at the minute but be nice to firm them up
Thanks for your help
