1.2 TSi CZJC Lumpy, stalled, wouldn't restart
Hey all,
I'm kind of cheating a little bit here because the engine might be in my sisters car but it's the CZJC 1.2 tsi that we're having issues with.
1.2 TSI EA211 January 2016 build
Whilst I personally have an overweight Polo (golf) my sisters car has a potentially serious problem.
I wondered if any of you guys may have any input on this at all please? My sisters car began running lumpy, threw the eml and then it cut out. The car would not restart. The timing belt has been changed (July) if that makes any difference to these error codes that are now stored :
P001100 A Camshaft Position (Bank1): Timing over-advanced or System Performance.
P030000 - Random misfire detected
P030100 - Cylinder 1 Misfire Detected
P030200 - Cylinder 2 Misfire Detected
P030300 - Cylinder 3 Misfire Detected
P030400 - Cylinder 4 Misfire Detected
Having cleared the faults, it then returned with a P008700 Fuel Rail/System Pressure - Too Low error. I wonder whether this might be because it wasn't managing to idle without increasing the revs and so the knock on for that was the reduced fuel pressure? The guys who did the cambelt came out, looked under the timing cover and said there were no teeth missing so that was that. There is however, a chirping noise coming from this area that did not exist before. The idle now I assume when it's switched to closed loop lambda control, is very, very lump with a equally unstable rev counter. What did concern me was that they referred to marks they'd made for the timing..... I thought those days were gone with how tight tolerances are on modern engines!
My worry is that the timing has potentially jumped OR the VVT pulley wasn't tightened up properly and it may have slipped - and as such I don't want to try and start it if the timing is physically out. Could this be caused by a failure of the solenoid that controls oil for the vvt or could it be another sensor? I'm guessing cam and crank both have sensors which I'll try and have a look at tomorrow but I'm very limited with what I can actually do.
Thanks for any advice you have, she's really saddened at this as she's owned the car for 9+ years and it's never gone wrong before this point!
Also, sorry to cheat and ask for my sisters car!
Thank you for any advice,
Mike
Recently Browsing 1
