Replacement bushes for Neuspeed 25mm rear ARB
I have a Neuspeed 25mm rear ARB and it has started knocking due to worn bushes. Awesome/Neuspeed say they only supply a full fitting kit with links and everything for £72. Does anyone know anywhere that does a 25mm bush set for the Octy (06 55plate 2.0 TDi PD140 Ambiente) ??? I've spoken to both Powerflex and Polybush, but they both only go to 24mm, which although close, would probably result in squeaking and exaggerated wear rate. Demon Tweeks and Jabba have nothing either.
Thanks in advance.
I have jut ordered superpro ones from a place on ebay I have an APR bar and the bushings were knackered, getting replacements was proving difficult so I ordered 27mm ones from TDC automotive on ebay, this is the link to the 25mm ones, comes with the brackets as well, worked a treat and much better quality than the ones supplied with the bar.
http://www.ebay.co.u...#ht_2290wt_1166
Hope this helps!!
Thanks for that, £38 is much more palatable than £72 ?
