Going to view a Fab VRS tonight - what to look out for?
Hi Guys, going to have a look at a Fab VRS tonight.
Anything in particular I should look out for on these?
No knocks from flywheel or gearbox, turbo pulls well, no oil on boost pipes. If its done over 60K check it's had water pump and timing belt done as it will save you a few hundred quid.
damp carpets in the back cause the doors are ******s!
Wet carpets from leaaking doors
Egr leaking, located right of the coolant bottle under the engine cover. Don't know ££.
Squeak from suspension when going over humps. Replace bushes at £100-200.
Coolant leaks, check for white residue on pipes and connections. Common one is theromostate leak.
Good luck :p
Sent from my Desire HD using Tapatalk
Thanks guys, it's on 69,000. I know it's had cambelt done but not sure about the water pump. I'll have a good look over it!
