oil temp pre fl
Is there any way of getting the oil temp to display on the maxidot ? Couldnt see anything on vcds, other than displaying it as a measuring block, but still trying to get used to it. I have the fiscon basic plus installed for the bt but the efma shows oil temp at -59 all the time
Failing this is there any guage a good match for the skoda green? i used to have the newsouth ones installed in my vw and they were a perfect match
Not sure how accurate this is but I've read on here that being able to view the oil temp depends on which service interval your car is set to. On fixed you can't see it whereas on variable you can?
Its supposed to be on varible just now but not checked
