Skoda Octavia 2010 FL 1.8 TSI fault codes
hello all :) , i own a octavia 2010 tsi , and i bought the vagcom cable lately , done an autodiagnostic test and 3 errors occur ...
VCDS Version: Beta 11.2.0
Data version: 20110305
Monday,21,May,2012,14:59:14:10074
Chassis Type: 1K0
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: TMBBK21Z0A2069403
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CDA) Labels: 06J-907-115-CDA.clb
Part No SW: 3T0 907 115 H HW: 1Z0 907 115 F
Component: 1.8l R4/4V TFSI 0040
Revision: AAH11--- Serial number:
Coding: 0203001024070060
Shop #: WSC 82500 819 87996
VCID: 366722EB3A87
1 Fault Found:
049409 - No Communication with Transmission Control Module
U0101 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 5
Mileage: 1048575 km
Time Indication: 0
Date: 2111.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 77.0°C
Temperature: 51.0°C
Absolute Pres.: 890.0 mbar
Voltage: 12.446 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 048 M HW: 0AM 927 769 D
Component: GSG DSG AG7 402 2680
Revision: 00040024 Serial number: TFK00911180476
Coding: 0000020
Shop #: WSC 10001 825 87996
VCID: 3A7F36DB0E9F
No fault code found.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 113B401C09280003880F02E4901C0041310000
Shop #: WSC 73430 790 00000
VCID: 7AFFF6DB4E1F
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AR HW: 3T0 907 044 AR
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
VCID: 820F0E3BA6CF
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0573
Revision: 00103 AF
Coding: 40180ABAB00508C04008008011000164430000AE424D89605C0440000000
VCID: 326F1EFBD6EF
Subsystem 1 - Part No: 1Z1 955 119 C
Component: Wischer 27110 22 0601
Coding: 00D7B7
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 1Z0 919 475 B HW: 1Z0 919 475
Component: PARKHILFE 4K H06 0006
Revision: -------- Serial number: 66640932409568
Coding: 100101
VCID: 408B44336843
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q1 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2H6P9M
Coding: 0020785
VCID: 3D753DC71FB1
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CE HW: 1K0 953 549 CE
Component: J0527 056 0111
Coding: 0001702
VCID: 77F9EFEF7D0D
Subsystem 1 - Part No: 3T0 959 537
Component: E221__MFL-URO H07 0012
Coding: 00000130
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 843 F HW: 1Z0 920 843 F
Component: KOMBI H05 0305
Serial number: 00000000000000
Coding: 110B00
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3B7133DF01A5
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0231
Revision: H16 Serial number: 4320K09B260776
Coding: EDA07F06000602001302
VCID: 69DDB9973BB9
1 Fault Found:
01315 - Transmission Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 43
Mileage: 35649 km
Time Indication: 0
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
VCID: EADF469BBEBF
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2113
Coding: 0004342
VCID: 76E7E2EB7A07
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 316D11F7D3E9
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Component: Tuer-SG 009 2119
Coding: 0004342
VCID: 489B5C134073
Address 56: Radio (J503) Labels: None
Part No SW: 1Z0 035 161 M HW: 1Z0 035 161 M
Component: Radio-SWING 001 0003
Revision: -----03S Serial number: SKZ4Z2L1397802
Coding: 0D0002000201
Shop #: WSC 08250 819 87996
VCID: 387B2CD33093
1 Fault Found:
01044 - Control Module Incorrectly Coded
Freeze Frame:
Fault Priority: 5
Fault Frequency: 146
Reset counter: 43
Mileage: 35411 km
Time Indication: 0
Date: 2025.14.15
Time: 10:20:15
Freeze Frame:
Bin. Bits: 010
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 326F1EFBD6EF
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 33611BFF29F5
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 E HW: 1Z0 035 729 E
Component: FSE_2P8x H40 0190
Revision: 00000000 Serial number: 00000005113834
Coding: 0000422
VCID: 3A7F36DB0E9F
End ---------------------------------------------------------------------
wts every error code mean ?
y in some part of the error code it show milage 104000 althu its only 35000 in reality ?
about after market HID , coding does not show any optoin for bixenon with no shutters , althu i have the lens and there is no HID regulation in here ,, thank you ! :)
Edited by da3bool
anyone ? :(
Have you seen the Ross-Tech Wiki info on the two codes below?
http://wiki.ross-tech.com/wiki/index.php/01315
http://wiki.ross-tech.com/wiki/index.php/01044
You haven't mentioned your car's transmission type so I am not sure if any of the threads below are of help in diagnosing the transmission fault code.
http://forums.tdiclub.com/showthread.php?t=312646
http://autos.groups.yahoo.com/group/VAG-COM/message/30773
http://www.audizine.com/forum/showthread.php/279823-Automatic-Transmission-Failing-!
Ross-Tech offer free support to users of their registered software but looking at the version of VCDS you are using I guess you are using a pirated lead and software.
hello DGW
sorry i forgut to mention its 7dsg , but i dunno y it shows an error ?! the car moves ok .. but with little jerking ... about the vcds yes its a pirated one ! :p
and its still under warranty , would they cancel my warranty bcz i showed them this error and i used vcds ?
No. The dealer will use their factory diagnostic equipment - rather than rely on your scan results - to confirm any faults before agreeing to fix them under warranty. Of the 3 faults, I would be most concerned about the transmission control module communication one and look to get that investigated asap. Let us know how you get on.
I will go to them asap ! But the problem is they always say the car is ok .. I have to show them that i know the exact problim so then they have to solve it ... The agency here sux :S could i know what are the options that can bring sucha error ? Thnx :)
Sent from my GT-I9100 using Tapatalk
