Can i swap ECU's !?!?
I was wondering if i can swap ECU's with my mate who has had his vRS Revo'd ?
You can, but I believe it will need some codings made to sync it with the car? J should be able to tell you more as he did this with his Jabba'd ECU :D
Chris
I would of thought the imobiliser would need tweeking as well ?
So not really, as i only want it for Croft on Saturday. I will have to show all the RS4 boys up in a stock car instead ;)
You need:
Both vRS in same vicinity:
YOUR four digit immobiliser code for your dashpod
HIS four digit immobiliser code for his dashpod
Plug in HIS ecu into your car, and use vag-com to log in to it using YOUR four pin code to log in to the system, then change it to HIS four digit code.
Do the same in reverse to allow him to use your ECU for a bit. :thumbup:
(and obviously reverse ALL the above to go back to normal).
I did this to get my Jabba'd ECU from my wreck, working in Fabia mkII. Took someone about 2 minutes to do the job. :D
Email Elton at Jabba :thumbup:
