bumper rubing light
does anyone elses drivers side rear light cluster rum on the bumper at all ??
i think i have traced it to been one of my squeek/rattles when going over speed bumps :)
Not sure if it's the light cluster, but my bumper certainly squeaks - not noticed it over speed bumps though.......
Chris
The light cluster is held in place by four nuts, accessible when the trim is removed and the carpet peled back. There is a little movement possible, so you may be able to cure your squeak by re-positioning the light cluster slightly.
The lower two bolt holes are shown in the photo, along with the clip that holds the bumper in place once all the screws are removed.
Mine squeeked, undo the light cluster screws, lift up light cluster re-tighten bolts, should solve problem. cheers Andy :thumbup:
cool will get the garage to do it when its in tomorrow ben serviced
