Dampness above Engine Management Module in Bonnet
Hi
I have a 2008 Fabia 2 Estate 1.9 TDI and I get Dampness above Engine Management Module on the front bulkhead black sound proofing material, below the scuttle. The previous dealer stated this was water from the air con drain but I suspect is it water from the scuttle drain holes? The stain has gone white and has been there for a few years.
Can any member help?
Brian
What condition is the rubber seal in that runs around the edge of the scuttle panel. Could be water getting in between the bonnet and this seal.
Same whitish stains on my Skoda cars, no problem. Water from the rain drain
