Bigger Turbo upgrade,
Afternoon all, i currently have a Stage 2 Fabia VRS, had the clutch uprated and everything, looking to go up to Stage 3 next, however im unsure if the worth for a Hybrid is really there for an extra Grand, or if i can just go for the PD150 turbo and another map, does anyone know any good companies that can produce or at least give me info about a bigger Turbo upgrade and where i could buy one from, as i believe the 130>150 is a straight swap??
Cheers, Tobe.
Try searching :)
Pd150 is good for 190ish bhp. Hybrid pd150 which uses either a 52 or 56 compressor wheel from a vnt20 is good for around 215bhp. After that your looking at the GTB turbos.
it's the torque that you need to consider transmitting to the tarmac through the front wheels!
stage 3 is a waste of money unless you get an atb diff and that spins away some of the torque to lose what u gain
jabbasport will be able to advise you mate!
In my opinion stage 2 is bigger turbo and a diff is not a 'necessity' i got a 14.4s 1/4 mile with no diff and only a mild 200bhp
to some extent (minus drag) torque = acceleration, bhp = top speed
what the torque output?
Torque was bang on 300lb-ft!
0-60ft time was mightly impressive, i think it was 1.6s
Terminal speed was 97mph
(diff not a necessity by any means)
Do you have a fmic?
1.6 seconds to 60ft? What was the spec of suspension, wheels, tyres etc? At santa pod? Thats epic fast to 60ft?!
Its all about the driver :)
Spec was
Kw v1 suspension
Helix and smf
S3 17" alloys with avon road tires
Bmc cda
Seat sport fmic
Td stage 2 hybrid 150
Brembo 323's
Full miltek with celi 100 cat
Not at santa pod but the 1/4mile was run by santa pod
Its the driver i tell you plus the car only had 195-200bhp
Do you have the 330ft time etc too?
Not not believing you, but got the slip? LOL.
My PB to 60ft is 2.06 seconds, on road tyres with a diff
No sorry it was a few years ago now, but im not joking it rocketed off the line, was just one of those awesome starts.
No wheel spin whatsoever and id didnt bog down at all, then quick change into second, was as perfect as it could have been!
Did you go on to run a 14.4? Just I cant see how that adds up, to be .4 seconds quicker to 60ft but then be .9 seconds after the 1/4 mile line?! I cant see how I make up 1.3 seconds over a 13 second run with only 20hp more?
I wish you had the slip, as then I would have to try harder with 2nd gear launchs as always.
Im not b.s.
The car had 195bhp and 300 lb-ft!
Yes it was a 14.4 run with 97mph terminal.
Was my fastest of the day with the rest being around 15s dead so theres the .6s
It was an awesome start
Having only 195bhp maybe have been an advantage off the line....? (less power and torque = less spin)
Edited by BigJase88
