cluncking noise coming from the a vrs mk octy
hi since av had the car av noticed a cluncking noise coming from the area near the aux belt tensioner also ..could this be the tensioner or the aircon..as when i turn the aircon on its not as load,,,any info would be greatfull
is the compressor running constantly?
my bet would be the belt tensioner/idler pulley
the aircon pump? no
do you no the part number/? cheers
no but it shouldnt be hard to find one. would be best to remove it and check it for play, can you see the belt reacting to the clunks? need to make sure its that for def first
no not off top of my head b ut would ber easy to find one.check it is this first. does the belt react as you here the clunks/noises? if it is that then get a good look at it and match it up with pics like this
http://www.ebay.co.u...#ht_2616wt_1140
dont know why i posted twice
Edited by Lofty79
cheers mate il check in the morning
